Infocus IN2124a 1024x768 3500 Lumens XGA DLP Projector
Quicklinx: BLLMWS00 Mfr#: IN2124A
The InFocus IN2124a projector combines high brightness, networking and low cost – making it perfect for schools with larger classrooms and low budgets.
InFocus IN2124a - DLP projector - standard lens - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Worldwide
Brightness
3500 lumens
Contrast Ratio
15000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Standard lens
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263, RV3, RV4
Storage Capacity
2 GB Flash
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 10.8 cm
3.2 kg
1-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Worldwide
Projector
Brightness
3500 lumens
Brightness (Reduced)
3200 lumens
Contrast Ratio
15000:1
Throw Ratio
1.9 - 2.2:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
Eco-Mode technology, Blackboard Mode, 6-segment colour wheel, Closed Caption, JPEG photo playback, MP3 playback, DLP 3D Ready, 16:9 aspect ratio support, Whiteboard Mode, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback, MP2 playback
Lens
Standard lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Digital Video Format
Media Player
Storage Capacity
2 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI input - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, FCC
29.2 cm
22 cm
10.8 cm
3.2 kg
Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
BLLM C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
