Infocus IN124STa 1024x68 3300 lumens XGA DLP Projector
Quicklinx: BLLRWS00 Mfr#: IN124STA
The InFocus IN120STa Series projectors combine short throw, high brightness, networking and low cost - making them perfect for classrooms, offices, or tight spaces like trade show booths. These value-packed projectors are easy to buy and built to perform with multiple ways to connect, beautiful image quality, and option to convert to an interactive projector. Plus, the short throw lens reduces shadows, prevents light from shining in the presenter's face, and saves space.
  • High brightness and high contrast
    The image quality of these projectors will not disappoint. 3300 lumens will give you bright, clear images with the lights on and the high 15000:1 contrast ratio adds sharpness with darker blacks and whiter whites. The short throw lens gives you big images in tight spaces and prevents light from shining in the presenter's face.
  • Make it interactive
    Plug in the optional LiteBoard adapter to turn your wall into an engaging, collaborative interactive workspace. Control all your favorite PC or Mac applications from around in the room with the wireless LiteBoard Wand just as you would with your mouse.
  • Easy display from any device
    Built-in apps and optional wireless adapter displays files from an Apple or Android notebook, tablet or smartphone. Or display from no device at all and project images, audio and video from the projector's on-board 2GB of memory.
  • Networking and room control
    Connect the projector to your network and manage it remotely. Send important announcements or emergency notifications for instant display, set up notifications for low lamp life, schedule when it gets powered down, and more. Crestron RoomView Connected and AMX Device Discovery technology is built into the projectors for easy connectivity, programming and control with those room control systems.
InFocus IN124STA - DLP projector - short-throw - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3300 lumens
Contrast Ratio
15000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263
Storage Capacity
2 GB Flash
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 10.8 cm
3.2 kg
1-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 lumens
Brightness (Reduced)
3000 lumens
Contrast Ratio
15000:1
Throw Ratio
0.6:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
Eco-Mode technology, 6-segment colour wheel, JPEG photo playback, MP3 playback, DLP 3D Ready, 16:9 aspect ratio support, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Digital Video Format
Media Player
Storage Capacity
2 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x network - RJ-45
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, FCC
29.2 cm
22 cm
10.8 cm
3.2 kg
Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
BLLR C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
