The value-packed IN124a DLP projector is easy to buy and provides multiple ways to display your content from mobile devices. Plus, its high brightness and contrast ratio displays outstanding images and its lightweight design makes it easy to move or install.
- InFocus IN124a - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker, 2GB flash
- Localisation
- Worldwide
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263, RV3, RV4
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 10.8 cm
- 2.44 kg
- 1-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Localisation
- Worldwide
Projector
- Brightness
- 3500 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 15000:1
- Throw Ratio
- 1.9 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- Eco-Mode technology, Blackboard Mode, 6-segment colour wheel, Closed Caption, JPEG photo playback, MP3 playback, BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, Whiteboard Mode, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- Digital Video Format
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, FCC
- 29.2 cm
- 22 cm
- 10.8 cm
- 2.44 kg
- Limited warranty - parts and labour - 1 year , Limited warranty - replacement - lamp - 6 months , Limited warranty - accessories - 90 days
- 0 °C
- 40 °C
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
