Infocus IN116x 1280x800 3200 Lumens WXGA 3D DLP Projector
Quicklinx: BLKZWS00 Mfr#: IN116X
Confidently beam your most important content with the high brightness and quality of the incredibly affordable IN116x widescreen projector.
It is built to perform with HDMI input, high brightness, WXGA native resolution, high contrast, and BrilliantColor technology. Plus, its compact design makes it easy to move or install.
InFocus IN116x - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
203 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 12.1 cm
2.45 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
15000:1
Image Size
759 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.5 - 1.8:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
203 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
6-segment colour wheel, BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Eco Blank
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B (management) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, NOM, PCT, SABS, SASO, CB, CCC, PSB, FCC, IRAM, KCC, KC, CECP, EAC
29.2 cm
22 cm
12.1 cm
2.45 kg
Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
BLKZ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
