If you're going mobile, take the InFocus LightPro IN1142 with you. The small, light and affordable LED projector features a maintenance-free lampless light source. At about the size of a paperback book and less than two pounds, the IN1142 is easy to pack in your bag and carry on. So you can go from place to place, presentation to presentation, without ever giving your projector a thought.
- InFocus LightPro IN1142 - DLP projector - portable
- DLP projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 700 lumens
- Contrast Ratio
- 10000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 65 Watt
- 17 cm x 13.8 cm x 4.25 cm
- 800 g
- 2-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 700 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 51 cm - 457 cm
- Projection Distance
- 0.9 m - 2.4 m
- Throw Ratio
- 1.4:1
- Uniformity
- 50 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- LED
- Bulb life cycle
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Dutch
- Auto Vertical Keystone, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support
Lens
- Focus Type
- Manual
- Zoom Factor
- 1.8x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Video Interfaces
- HDMI
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x HDMI cable
- CB, FCC
- Voltage Required
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- 17 cm
- 13.8 cm
- 4.25 cm
- 800 g
- Limited warranty - 2 years , Limited warranty - accessories - 90 days
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 34 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
