The InFocus IN1110A series of projectors deliver bright, clear images from your notebook, tablet or smartphone no matter where you are.
The combination of high brightness, light weight and compact size is ideal for the traveling professional that faces unpredictable environments every day. Whether you're in a brightly lit room or cramped for time and space, the IN1110A series is the mobile projector you can count on to perform every time.
Document annotation
Free wireless presentation app lets you annotate on documents you're presenting with a wide variety of colored pens and shapes and then save the changes. -
No computer needed
Present photos, PPT presentations, spreadsheets, PDFs, audio, video, and more directly from a USB thumb drive. -
Compact and light
The IN1110A is easy to pack, easy to carry and won't weigh you down. -
Connect fast
Connect your notebook or tablet via HDMI or USB to present full HD quality video (and audio too) in just seconds. VGA and composite video ports are also included for when the need arises. You can even connect it to an external audio system with the audio out port. -
Built for the road
The projector has a recessed lens and tethered lens cap to keep it safe from impact. Plus, its smooth exterior leaves nothing to snag or break off when taking it in and out of its case. -
Brightness adds confidence
Room lighting can be a wildcard for the business traveler. You never know what you'll get. Gram-for-gram these powerful little projectors pump out the most lumens of most any other projector. So you know your content will be brightly displayed regardless of ambient light.
- InFocus IN1110A - DLP projector - portable - 3D - black
- DLP projector
- 3D Capable
- Black
- Built-in Devices
- Speaker
- Localisation
- Worldwide
- Brightness
- 2100 lumens
- Contrast Ratio
- 2600:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 16.7 million colours
- Bulb type
- 165 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 185 Watt
- 21.3 cm x 18.1 cm x 6.5 cm
- 1.2 kg
- 2-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- Black
- Localisation
- Worldwide
Projector
- Brightness
- 2100 lumens
- Brightness (Reduced)
- 1550 lumens
- Contrast Ratio
- 2600:1
- Image Size
- 56 cm - 615 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.95 - 2.15:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 165 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
- Blackboard Mode, Closed Caption, 5-segment colour wheel, 16:9 aspect ratio support, Whiteboard Mode, 16:10 aspect ratio support, 5:4 aspect ratio support, upgradable firmware
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x management - 4 pin USB Type A
- Included Accessories
- Carrying case, lens cover, lens cap strap, remote control
- Cables Included
- 1 x USB adapter , 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code
- TUV GS, C-Tick, GOST, NOM, SABS, SASO, CCC, PSB, FCC, WEEE, cULus, S Mark, SONCAP, CECP
- Voltage Required
- 185 Watt
- 21.3 cm
- 18.1 cm
- 6.5 cm
- 1.2 kg
- Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- 5 °C
- 35 °C
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
