iiyama XUB2792QSU-B1 27" 2560x1440 5ms DVI HDMI HA Monitor
Clearance!
Clearance
Quicklinx: CMNYWS00 Mfr#: XUB2792QSU-B1
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£252.63 ex VAT
£303.15 inc VAT
Stylish ultra-flat front design makes the ProLite perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the WQHD (2560 x 1440) resolution means the XUB2792QSU can accommodate more information on the screen. High contrast and brightness values enable the monitor will provide excellent performance for photographic and web design, and the height-adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
  • WQHD
    With true WQHD 2560 x 1440p resolution your monitor is ready to display high-definition images. This means you can accommodate more information on your screen.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles. The screen will look good no matter from what angle you look at it.
  • HAS and pivot
    With a height-adjustable stand you will create an ergonomic work posture and position, that meets all health and safety requirements. This will not only prevent any health issues, but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful, if the application requires more height than width.
  • Flicker-free and blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite XUB2792QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34.4 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
61.1 cm x 23 cm x 39.7 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, CU
Display Type
Energy Class
Class B
50 kWh
34.4 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Matte, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, FreeSync Technology
6.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
33 Watt
ENERGY STAR Certified
iiyama XUB2792QSU-B1 27 Bundle deal on iiyama XUB2792QSU-B1 27" 2560x1440 5ms DVI HDMI HA Monitor
£351.80
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
