iiyama XUB2495WSU-B1 24"1920 x 1200 5ms VGA HDMI DP LED Monitor
Quicklinx: DQSNWS00 Mfr#: XUB2495WSU-B1
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£185.97 ex VAT
£223.16 inc VAT
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen.
  • IPS technology
  • Blue light reducer
  • Overdrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
iiyama ProLite XUB2495WSU-B1 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
53.2 cm x 23 cm x 39.7 cm
5.88 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
3-year warranty
Display Type
Energy Class
Class A+
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
46 - 66 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
5.88 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable
Security Slot Type
Kensington security slot
23 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
