iiyama XU2590HS-B1 25" 1920x1080 HDMI IPS Monitor
CLEARANCE!
Clearance
Quicklinx: BD0SWS00 Mfr#: XU2590HS-B1
ProLite XU2590HS is a 25" LED backlit LCD screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and fast response time (5 ms black-to-black). XU2590HS is full HD, has a > 5mln:1 Advanced Contrast Ratio and 250 cd/m2 brightness offering the user a clear and vivid image. The ProLite XU2590HS will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment. Very suitable for multi-monitor Digtal Signage and office applications.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Overdrive ON/OFF
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XU2590HS-B1 - LED monitor - Full HD (1080p) - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25.1 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.288 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
57.75 cm x 18 cm x 40.75 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, DDC/CI, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
37 kWh
25.1 W
Diagonal Size
25"
Viewable Size
25"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.288 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, blue reduction
OSD Languages
Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), blue light reduction, i-Style Color
57.75 cm x 18 cm x 40.75 cm - with stand
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-4/+20
VESA Mounting Interface
100 x 100 mm
Cable management cover
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
26 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
Dimensions & Weight Details
Without stand - width: 57.75 cm - depth: 4.5 cm - height: 33.95 cm , With stand - width: 57.75 cm - depth: 18 cm - height: 40.75 cm - weight: 4.4 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
BD0S C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BD0S C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.18
BD0S C2G 5m Select High Speed HDMI with Ethernet In Stock £20.65
BD0S C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
