iiyama XB2481HS-B1 23.6" 1920x1080 6ms VGA DVI HDMI LED Monitor
Quicklinx: BD0LWS00 Mfr#: XB2481HS-B1
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£107.50 ex VAT
£129.00 inc VAT
ProLite XB2481HS is a 24" LED backlit LCD Screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 3000:1 Native Contrast Ratio, the Prolite XB2481HS provides excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
  • HAS + PIVOT
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • ACR
    Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
iiyama ProLite XB2481HS-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25.5 W
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
54.35 cm x 23 cm x 40.7 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class B
37 kWh
25.5 W
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, luminance
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
Cable management cover, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
54.35 cm x 23 cm x 40.7 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , HDMI , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
25 Watt
On / Off Switch
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8
ENERGY STAR Certified
Limited warranty - 3 years
BD0L StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.82
BD0L StarTech.com Articulating Monitor Arm In Stock £103.13
BD0L StarTech.com Dual Monitor Stand In Stock £70.24
BD0L StarTech.com Cubicle Monitor Hanger In Stock £46.01
BD0L StarTech.com TV/Monitor Arm - Wallmount In Stock £66.06
Diagonal Size: 24in
Response Time: 6ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
