ProLite XB2481HS is a 24" LED backlit LCD Screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 3000:1 Native Contrast Ratio, the Prolite XB2481HS provides excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
HAS + PIVOT
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
ACR
Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
- iiyama ProLite XB2481HS-B1 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 21.3 W
- Stereo speakers
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.35 cm x 23 cm x 40.7 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, ISO 9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 37 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Built-in Devices
- Stereo speakers
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, luminance
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
- Black
- 54.35 cm x 23 cm x 40.7 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , HDMI , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 21.3 W
- Power Consumption SDR (On mode)
- 21.3 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- On / Off Switch
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista/7/8
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
