iiyama XB2283HSUB1DP 21.5" 1920x1080 5ms VGA DVI DP USB LED Monitor
Quicklinx: BPGNWS00 Mfr#: XB2283HSU-B1DP
The ProLite XB2283HSU-B1DP is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple Input support and USB HUB ensure compatibility with the latest installed graphics cards and embedded notebook outputs. The ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. A perfect solution for education, local government, business and finance markets.
  • VA Matrix
    VA panel technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XB2283HSU-B1DP - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 18 ms (typical)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
50.5 cm x 23 cm x 39.35 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, DDC/CI, VCCI Class B
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
50.5 cm x 23 cm x 39.35 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA (HD-15) , DVI-D , DisplayPort , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Input Voltage
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm , With stand - width: 50.5 cm - depth: 23 cm - height: 39.35 cm - weight: 4.8 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
BPGN C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
