iiyama X2481HS-B1 23.6" 1920x1080 6ms VGA DVI HDMI LED Monitor
Quicklinx: BD0GWS00 Mfr#: X2481HS-B1
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£87.71 ex VAT
£105.25 inc VAT
ProLite X2481HS - a 24" LED backlit LCD screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 3000:1 Native Contrast Ratio, the Prolite X2481HS provides excellent performance for photographic, design and web-design.
iiyama ProLite X2481HS-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25.5 W
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
54.35 cm x 21.35 cm x 38.9 cm
3.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class B
37 kWh
25.5 W
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, luminance
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
Cable management cover, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
3.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-4/+21
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
25 Watt
On / Off Switch
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8
ENERGY STAR Certified
Limited warranty - 3 years - on-site
iiyama X2481HS-B1 23.6 Bundle deal on iiyama X2481HS-B1 23.6" 1920x1080 6ms VGA DVI HDMI LED Monitor
£186.88
Diagonal Size: 24in
Response Time: 6ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
