iiyama X2283HSU-B1DP 21.5" 1920x1080 VGA DVI DP USB LED Monitor
Excellent 22" Full HD LED-backlit Monitor!
Quicklinx: BPGMWS00 Mfr#: X2283HSU-B1DP
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
41 in stock
£93.57 ex VAT
£112.28 inc VAT
It is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. It is an affordable solution for education, local government, business and finance markets.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high-definition images. This means you can accommodate more information on your screen.
  • OverDrive on / off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers
    This LED monitor is equipped with two high-quality stereo speakers.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite X2283HSU-B1DP - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
18 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
50.5 cm x 19.3 cm x 38.25 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, DDC/CI, TCO Displays 6.0, VCCI Class B
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
50.5 cm x 19.3 cm x 38.25 cm - with stand
2.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , DisplayPort , Headphones , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm , With stand - width: 50.5 cm - depth: 19.3 cm - height: 38.25 cm - weight: 2.8 kg
ENERGY STAR Certified
iiyama X2283HSU-B1DP 21.5 Bundle deal on iiyama X2283HSU-B1DP 21.5" 1920x1080 VGA DVI DP USB LED Monitor
£192.74
BPGM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.28
BPGM C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.40
BPGM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BPGM C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.66
BPGM C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.34
BPGM C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.35
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
