iiyama Touchscreen Monitor
Quicklinx: CNGPWS00 Mfr#: T2435MSC-B2
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
Hurry, only 1 left in stock!
£246.30 ex VAT
£295.56 inc VAT
With Full HD resolution and projective capacitive 10 point touch technology, the ProLite display delivers seamless and accurate touch response. Featuring VA LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand, allowing the monitor to lay down completely flat for use as a giant tablet. The T2435MSC comes equipped with several video inputs and a USB 2.0 as well as integrated stereo speakers delivering good-quality sound. An ideal screen for interactive digital signage, InStore retail, gaming and interactive presentations purposes.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass, that covers the screen. Touch is detected because electrical characteristics of the sensor grid change, when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected, even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • Scratch-resistance
    Scratch-resistance is essential for touch solutions, used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It enables high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite T2435MSC-B2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24.1 W
Touch-screen, microphone, camera, USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
57.1 cm x 4.45 cm x 34.75 cm
6.2 kg
VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
35 kWh
24.1 W
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
Microphone, camera, USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Brightness w/touchscreen
215 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
Eco-Mode, HID Compliant, X-Res Technology, 10-point multi-touch, blue light reduction, i-Style Color
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , USB 2.0 (Type B)
Mechanical
Tilt
Tilt Angle
+15/+70
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), built-in adjustable tilt stand
1 x DVI cable - DVI-D to DVI-D , 1 x Mini DisplayPort-DisplayPort cable , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8
iiyama Touchscreen Monitor Bundle deal on iiyama Touchscreen Monitor
£345.47
Diagonal Size: 24in
Response Time: 6ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
