MD BRPCV02 is a high quality bracket that allows a mini PC or thin client to be mounted to the iiyama height adjustable stand.
Efficient mounting
Designed specifically for mini PCs, the MD BRPCV02 offers a seamless mounting experience, allowing users to easily attach their devices to monitors for a streamlined workspace. -
Versatile compatibility
Featuring a VESA mount bracket with a flat panel mount interface of 100 x 100 mm, this mounting component is compatible with a wide range of monitors, ensuring a secure and stable setup.
- Iiyama MD BRPCV02 mounting component - for mini PC - black
- Product Type
- Mounting component - monitor
- Mounting Components
- VESA mount bracket
- Recommended Use
- Mini PC
- VESA Mounting Interface
- 100 x 100 mm
- Black
- 5-year warranty
- Designed For
- ProLite B2083HSD-1, GB2773HS-1, XB2483HSU-1, XB2776QS-1, XB2779QS-1, XB2783HSU-1, XUB2495WSU-B1, XUB2790HS-1
- Black
AV Furniture
- Recommended Use
- Mini PC
- Placing / Mounting
- Monitor
- 100 x 100 mm
- Limited warranty - 5 years
- Designed For
- Iiyama ProLite B2083HSD-1, GB2773HS-1, XB2483HSU-1, XB2776QS-1, XB2779QS-1, XB2783HSU-1, XUB2495WSU-B1, XUB2790HS-1
