With Full HD resolution and Projective Capacitive 12-point touch technology, the ProLite TF5537MSC-B2AG delivers seamless and accurate touch response. Featuring an IPS Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel. The open frame ProLite TF5537MSC-B2AG is the ideal solution for interactive digital signage, instore retail, kiosks and interactive presentations.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger and magnetic ball. -
Palm rejection function
Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
AG coating
The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TF5537MSC-B2AG 55" Class (54.6" viewable) LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, IR extender, batteries, cable clamp
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 76 Watt
- Power Consumption (On mode)
- 114 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 168 kWh
- 129.45 cm x 6.75 cm x 76.55 cm
- 45.7 kg
- Product Type
- Energy Class
- Class B
- 76 Watt
- 114 W
- 168 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- 129.45 cm
- 6.75 cm
- 76.55 cm
- 45.7 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 6H Hard
- Image Contrast Ratio
- 1100:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 12 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio input , Serial output , USB , Infrared input
- IR extender, batteries, cable clamp
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
