iiyama TF5537MSC-B2AG 55" 1920x1080 VGA DVI HDMI Touch LFD
Quicklinx: CW6QWS00 Mfr#: TF5537MSC-B2AG
  • 1080p (Full HD)
With Full HD resolution and Projective Capacitive 12-point touch technology, the ProLite TF5537MSC-B2AG delivers seamless and accurate touch response. Featuring an IPS Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel. The open frame ProLite TF5537MSC-B2AG is the ideal solution for interactive digital signage, instore retail, kiosks and interactive presentations.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger and magnetic ball.
  • Palm rejection function
    Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TF5537MSC-B2AG 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Diagonal Size
54.6 in
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
76 Watt
Power Consumption (On mode)
114 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
168 kWh
129.45 cm x 6.75 cm x 76.55 cm
45.7 kg
Energy Class
Class B
76 Watt
114 W
168 kWh
Diagonal Class
55"
Diagonal Size
54.6 in
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode
129.45 cm
6.75 cm
76.55 cm
45.7 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 6H Hard
Image Contrast Ratio
1100:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
12 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
VESA Mounting Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Audio input , Serial output , USB , Infrared input
IR extender, batteries, cable clamp
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
Power supply
Nominal Voltage
0.5 Watt
