iiyama TF4637MSC-B2AG 46" 1920x1080 VGA DVI HDMI Touch LFD
Quicklinx: CW6NWS00 Mfr#: TF4637MSC-B2AG
  • 1080p
With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF4637MSC-B2AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands the 60950-1 ball drop test, making it suitable for demanding environments like table top integration. The open frame ProLite TF4637MSC-B2AG is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • Ball-drop-test proof
    The ball-drop-test uses a half-kilo steel ball, which is dropped onto the touch screen from a height of 1.3 meter. If the touch screen surface remains unaffected, the monitor passes the ball-drop-test for high impact resistance and durability.
iiyama ProLite TF4637MSC-B2AG 46" LED-backlit LCD display - Full HD - for digital signage / interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
46"
Commercial Use
Yes - interactive digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, clamper
Voltage
Energy Class
Class B
90 Watt
Power Consumption Stand by
0.5 Watt
110 cm x 8.9 cm x 65.45 cm
34 kg
Energy Class
Class B
90 Watt
Diagonal Class
46"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
Dimensions
Without stand
110 cm
8.9 cm
65.45 cm
34 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 6H Hard
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
6.5 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish
Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 7 Watt
Connector Type
DVI-D input , VGA input , USB , HDMI input , Serial input , Audio input , 2 x speakers output
Clamper
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
Power supply
Input Voltage
0.5 Watt
On / Off Switch
