iiyama TF4338MSC-B2AG 43" 1920x1080 12ms VGA DVI HDMI DisplayPort Touch IPS LED Large Format Display
Quicklinx: FJ3HWS00 Mfr#: TF4338MSC-B2AG
32 in stock
£1,231.76 ex VAT
£1,478.11 inc VAT
The Full HD TF4338MSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The PCAP touch technology with 12 touch points ensures a seamless and accurate touch response. Featuring a metal housing, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in demanding environments for maximum flexibility and accessibility.
iiyama ProLite TF4338MSC-B2AG - LED monitor - Full HD (1080p) - 43"
LED-backlit LCD monitor - 43" - touchscreen
Energy Class
Class A
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.4902 mm
Brightness
450 cd/m²
Contrast Ratio
1100:1
Response Time
12 ms
Colour Support
16.7 million colours (6-bit)
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Screen Coating
7H Hard Coating
987.5 mm x 68 mm x 587.7 mm
21.6 kg
CB, cULus, REACH, IP54, TUV Bauart, EAC, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class A
Diagonal Size
43"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.4902 mm
Brightness
450 cd/m²
Brightness w/touchscreen
380 cd/m²
Contrast Ratio
1100:1
Colour Support
Response Time
12 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Anti-glare, High Frame Rate Control (Hi-FRC), edge-to-edge glass, OSD lock, HID Compliant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode, palm rejection function, kiosk mode
21.6 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI , 2 x HDMI , DisplayPort , Audio line-out , Audio line-in , Network , RS-232C , IR in/out
Mechanical
VESA Mounting Interface
400 x 200 mm
Security lock slot (cable lock sold separately), IP54 protection, HDCP Compliant, 84% light transmittance
Remote control
1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x IR extender cable
Security Slot Type
Kensington security slot
75 Watt
Power Consumption Stand by
1 Watt
Power Consumption (Off Mode)
1 Watt
Linux, Microsoft Windows
Limited warranty - 3 years
Brand: iiyama
Price Range Ex VAT: 1000 - 1500
