iiyama TF4237MSC-B4AG 42" 1920x1080 VGA DVI HDMI Touch LFD
Quicklinx: CW6LWS00 Mfr#: TF4237MSC-B4AG
  • 1080p
With 1920x1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF4237MSC-B4AG delivers seamless and accurate touch response. Featuring an AMVA3 LED LCD screen technology, it offers exceptional colour performance, high contrast and wide viewing angles, making it a perfect display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands the 60950-1 ball drop test, making it suitable for demanding environments like table top integration. The ProLite TF4237MSC-B4AG is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
iiyama ProLite TF4237MSC-B4AG 42" LED-backlit LCD display - Full HD - for digital signage / interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - interactive digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, remote control, batteries, cable clamp
Voltage
Energy Class
Class B
70 Watt
Power Consumption (On mode)
75 W
Energy Consumption per Year
109 kWh
97.55 cm x 6.95 cm x 57.5 cm
25 kg
Energy Class
Class B
70 Watt
75 W
109 kWh
Diagonal Class
42"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
97.55 cm
6.95 cm
57.5 cm
25 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
4000:1
Brightness
420 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 14 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Audio input , USB , RS-232C
Remote control, batteries, cable clamp
VGA cable , DVI cable , USB cable , IR extender cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Input Voltage
