iiyama TF3238MSC-B2AG 32" 1920x1080 8ms VGA DVI HDMI DisplayPort Touch LED Large Format Display
Quicklinx: FJ3DWS00 Mfr#: TF3238MSC-B2AG
The Full HD (1920 x 1080) Open Frame TF3238MSC is the ideal interactive display solution for education, kiosks, interactive Digital Signage and in-store communications. It can be installed in landscape, portrait and face-up orientation for maximum flexibility and accessibility. The Projective Capacitive (PCAP) touch technology with 12 touch points ensures a seamless and accurate touch response. With its AMVA3 LED panel, it offers exceptional color performance, high contrast and wide viewing angles. Featuring a metal housing with a 60950-1 ball-drop proof, scratch-resistant, edge-to-edge glass, this display can be installed in the most demanding environments and build in different set-ups as a result of its Open Frame side mounting holes.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Touch through-glass
    This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
iiyama ProLite TF3238MSC-B2AG 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort
AMVA3
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, remote control
Voltage
Energy Class
Class B
60 Watt
Power Consumption (On mode)
56 W
Energy Consumption per Year
81 kWh
74.85 cm x 6.8 cm x 45 cm
14.5 kg
Energy Class
Class B
60 Watt
56 W
81 kWh
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
Protection
Super-clear anti-glare screen
Dimensions
Without stand
74.85 cm
6.8 cm
45 cm
14.5 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
7H Hard
Image Contrast Ratio
3000:1
Brightness
500 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
150 degrees
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
3M Projected Capacitive Technology (PCAP)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DisplayPort input , 2 x HDMI , USB , Audio line-out , Audio line-in , DVI-HDCP
Remote control
DisplayPort cable , USB cable , HDMI cable , IR extender cable
DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
Power supply
Input Voltage
On / Off Switch
