With Full HD resolution and Projective Capacitive 12-point touch technology, the ProLite delivers seamless and accurate touch response. Featuring an AMVA3 edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands drops, making it suitable for demanding environments, like table top integration. The open frame ProLite is the ideal solution for interactive digital signage, instore retail, kiosks and interactive presentations.
Capacitive touch technology
This technology uses a sensor-grid of micro-fine wires, integrated into the glass, that covers the screen. Touch is detected, because electrical characteristics of the sensor grid change, when human finger is placed on the glass. Thanks to the glass overlay, this technology is highly durable, and the touch function remains unaffected, even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Palm rejection function
Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for some time, it will automatically return to the finger mode. -
Open frame
Open frame monitor is an ideal solution for kiosk integrators and instore retail. -
AG coating
The anti-glare coating is used in this professional-grade display to help avoid issues with reflections and external light sources, affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TF3237MSC-W3AG 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- White
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries, IR extension cable, cable clamp
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 48 Watt
- Power Consumption (On mode)
- 54.2 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 79 kWh
- 78.15 cm x 6.9 cm x 47.6 cm
- 17.3 kg
- Product Type
- Energy Class
- Class B
- 48 Watt
- 54.2 W
- 79 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Design
- Metal frame
- 78.15 cm
- 6.9 cm
- 47.6 cm
- 17.3 kg
- Enclosure Colour
- White
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare, 6H Hard
- Image Contrast Ratio
- 3000:1
- Brightness
- 420 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
- Batteries, IR extension cable, cable clamp
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 0 - 85% (non-condensing)
