iiyama TF3237MSC-W3AG 32" 1920x1080 DVI VGA Large Format Display
Quicklinx: CC95WS00 Mfr#: TF3237MSC-W3AG
  • 1080p
With Full HD resolution and Projective Capacitive 12-point touch technology, the ProLite delivers seamless and accurate touch response. Featuring an AMVA3 edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands drops, making it suitable for demanding environments, like table top integration. The open frame ProLite is the ideal solution for interactive digital signage, instore retail, kiosks and interactive presentations.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires, integrated into the glass, that covers the screen. Touch is detected, because electrical characteristics of the sensor grid change, when human finger is placed on the glass. Thanks to the glass overlay, this technology is highly durable, and the touch function remains unaffected, even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Palm rejection function
    Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for some time, it will automatically return to the finger mode.
  • Open frame
    Open frame monitor is an ideal solution for kiosk integrators and instore retail.
  • AG coating
    The anti-glare coating is used in this professional-grade display to help avoid issues with reflections and external light sources, affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TF3237MSC-W3AG 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
White
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, batteries, IR extension cable, cable clamp
Voltage
Energy Class
Class B
48 Watt
Power Consumption (On mode)
54.2 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
79 kWh
78.15 cm x 6.9 cm x 47.6 cm
17.3 kg
Energy Class
Class B
48 Watt
54.2 W
79 kWh
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
Design
Metal frame
78.15 cm
6.9 cm
47.6 cm
17.3 kg
Enclosure Colour
White
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare, 6H Hard
Image Contrast Ratio
3000:1
Brightness
420 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
Batteries, IR extension cable, cable clamp
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
Power supply
Input Voltage
0.5 Watt
On / Off Switch
0 - 85% (non-condensing)
