With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF3237MSC-B3AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands the 60950-1 ball drop test, making it suitable for demanding environments like table top integration. The open frame ProLite TF3237MSC-B3AG is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks and Interactive Presentations.
Ball-drop-test proof
The ball-drop-test uses a half-kilo steel ball, which is dropped onto the touch screen from a height of 1.3 meter. If the touch screen surface remains unaffected, the monitor passes the ball-drop-test for high impact resistance and durability. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
Open frame
Open frame monitors are an ideal solution for kiosk integrators and Instore Retail. -
Palm rejection function
Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode.
- iiyama ProLite TF3237MSC-B3AG 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, clamper
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 48 Watt
- Power Consumption (On mode)
- 54.2 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 79 kWh
- 78.15 cm x 6.9 cm x 47.6 cm
- 17.3 kg
- Product Type
- Energy Class
- Class B
- 48 Watt
- 54.2 W
- 79 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Portrait mode, landscape mode, Face-up Mode
- 78.15 cm
- 6.9 cm
- 47.6 cm
- 17.3 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare, 6H Hard, glass coating
- Image Contrast Ratio
- 3000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 14 Watt
- Speakers
- 2 x main channel speaker - 7 Watt
- Connector Type
- DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
- Clamper
- Cables Included
- VGA cable , DVI cable , USB cable , IR extender cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
