Product
iiyama TF3237MSC-B3AG 32" 1920x1080 DVI VGA Large Format Display
Quicklinx: CC94WS00 Mfr#: TF3237MSC-B3AG
  • 1080p (Full HD)
With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF3237MSC-B3AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands the 60950-1 ball drop test, making it suitable for demanding environments like table top integration. The open frame ProLite TF3237MSC-B3AG is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks and Interactive Presentations.
  • Ball-drop-test proof
    The ball-drop-test uses a half-kilo steel ball, which is dropped onto the touch screen from a height of 1.3 meter. If the touch screen surface remains unaffected, the monitor passes the ball-drop-test for high impact resistance and durability.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • Open frame
    Open frame monitors are an ideal solution for kiosk integrators and Instore Retail.
  • Palm rejection function
    Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode.
iiyama ProLite TF3237MSC-B3AG 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
48 Watt
Power Consumption (On mode)
54.2 W
Energy Consumption per Year
79 kWh
78.15 cm x 6.9 cm x 47.6 cm
17.3 kg
Energy Class
Class B
48 Watt
54.2 W
79 kWh
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
78.15 cm
6.9 cm
47.6 cm
17.3 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 6H Hard, glass coating
Image Contrast Ratio
3000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
Clamper
VGA cable , DVI cable , USB cable , IR extender cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
