With 1920x1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF3222MC-B2 delivers seamless and accurate touch response. Featuring AMVA3 LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. The high brightness (500 cd/m²) ensures crispy and clear images, resulting in outstanding information transmission performance, even in bright environments. In addition to the superb image quality, the screen comes with a rugged bezel, making it suitable for demanding environments. The open frame ProLite TF3222MC-B2 is the ideal solution for Interactive Digital Signage, In-store Retail, Kiosks, Gaming and Interactive Presentations.
AMVA3 technology
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Capacitive touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. -
Palm rejection function
Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode. -
Open frame LFD
Open frame monitors feature special mounting screw holes on all sides of the monitor that can be used for installing the monitor. Open Frame monitors are an ideal solution for kiosk integrators and In-store Retail. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF3222MC-B2 - LED monitor - Full HD (1080p) - 32"
- LED-backlit LCD monitor - 32" - touchscreen
- Touch-screen
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.364 mm
- Brightness
- 500 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- DVI-D, VGA
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 74.85 cm x 6.3 cm x 45 cm
- 12.8 kg
- Plug and Play, DDC-2B, cULus, TUV Bauart, CU
- Display Type
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.364 mm
- Brightness
- 500 cd/m²
- Brightness w/touchscreen
- 425 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 47 - 63 Hz
- Horizontal Refresh Rate
- 31.47 - 67.5 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- OSD lock, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, palm rejection function
- Black
- 12.8 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D , USB (Type B)
Mechanical
- VESA Mounting Interface
- 200 x 200 mm
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 48 Watt
- Power Consumption Stand by
- 1.5 Watt
