With Full HD resolution and Projective Capacitive 10 point touch technology, the ProLite TF3222MC-B1 delivers seamless and accurate touch response. Featuring AMVA3 LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. The high brightness ensures crispy and clear images, resulting in outstanding information transmission performance, even in bright environments. In addition to the superb image quality, the screen comes with a rugged bezel, making it suitable for demanding environments.
AMVA3
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Palm rejection function
Palm rejection is a way to disregard signal from finger while using the pen mode. When you touch the screen with a pen, and your palm is touching the monitor, palm rejection is activated and the screen does not recognize touch made with the finger. If the screen is not touched for 1 second, it will automatically return to the finger mode. -
Open frame
Open frame monitors are an ideal solution for kiosk integrators and Instore Retail. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF3222MC-B1 - LED monitor - Full HD (1080p) - 32"
- LED-backlit LCD monitor - 32" - touchscreen
- Touch-screen
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.364 mm
- Brightness
- 500 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Screen Coating
- 8H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 74.85 cm x 6.2 cm x 45 cm
- 12.5 kg
- DDC-2B, VESA DPMS, cULus, TUV Bauart, CU
- Display Type
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.364 mm
- Brightness
- 500 cd/m²
- Brightness w/touchscreen
- 425 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 47 - 63 Hz
- Horizontal Refresh Rate
- 31.47 - 67.5 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 8H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
- Black
- 12.5 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D , USB (Type B)
Mechanical
- VESA Mounting Interface
- 200 x 200 mm
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 48 Watt
- OS Required
- Linux, Microsoft Windows 7 / 8 / 10
