The Full HD (1920 x 1080) T4361MSC is the ideal interactive display solution for education, interactive digital signage and instore communications. The Projective Capacitive (PCAP) touch technology with 40 touch points ensures a seamless and accurate touch response. Featuring scratch-resistant metal housing, edge-to-edge glass and an AMVA3 LED panel, this display can be used in landscape and portrait orientation in the most demanding environments for maximum flexibility and accessibility.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
24/7
24/7 displays are designed for a continuous operation.
- iiyama ProLite T4361MSC-B1 - LED monitor - Full HD (1080p) - 43"
- LED-backlit LCD monitor - 43" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 111 kWh
- Power Consumption (On mode)
- 76 W
- Touch-screen, stylus, USB 3.0 hub
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.49 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 4000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Screen Coating
- 7H Hard Coating, anti-smudge coating, matte
- Voltage
- AC 100/240 V (50 Hz)
- Black
- 98.3 cm x 8.25 cm x 57.15 cm
- 19.5 kg
- Plug and Play, DDC-2B, VESA DPMS, UL 60950, CB, CCC, RoHS, WEEE, cULus, REACH, SVHC, CU, DisplayPort 1.2, IP65 front
- Display Type
- Energy Class
- Class B
- 111 kWh
- Diagonal Size
- 43"
- Viewable Size
- 42.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- A-MVA3
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.49 mm
- Brightness
- 400 cd/m²
- Brightness w/touchscreen
- 336 cd/m²
- Contrast Ratio
- 4000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 47 - 63 Hz
- Horizontal Refresh Rate
- 30 - 73 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- HDCP, High Frame Rate Control (Hi-FRC), edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, OPS slot
- Black
- 19.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 8 Watt
Input
- Touch-screen, stylus - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA (HD-15) , HDMI (HDCP) , DisplayPort , USB upstream (Type B) , Audio line-in , DVI-D , Management (RJ-11)
Mechanical
- VESA Mounting Interface
- 400 x 400 mm
- Security lock slot (cable lock sold separately), metal housing, 84% light transmittance, 3 mm glass
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 76 W
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Driver
- Shipping Width
- 113 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 71 cm
- Shipping Weight
- 25 kg
