iiyama T4361MSC-B1 43" 1920z1080 8ms VGA DVI HDMI DisplayPort Touch LED Large Format Display
Quicklinx: FJ3JWS00 Mfr#: T4361MSC-B1
TV Tuner Presence: No
£1,383.53 ex VAT
£1,660.23 inc VAT
The Full HD (1920 x 1080) T4361MSC is the ideal interactive display solution for education, interactive digital signage and instore communications. The Projective Capacitive (PCAP) touch technology with 40 touch points ensures a seamless and accurate touch response. Featuring scratch-resistant metal housing, edge-to-edge glass and an AMVA3 LED panel, this display can be used in landscape and portrait orientation in the most demanding environments for maximum flexibility and accessibility.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • 24/7
    24/7 displays are designed for a continuous operation.
iiyama ProLite T4361MSC-B1 - LED monitor - Full HD (1080p) - 43"
LED-backlit LCD monitor - 43" - touchscreen
Energy Class
Class B
Energy Consumption per Year
111 kWh
Power Consumption (On mode)
76 W
Touch-screen, stylus, USB 3.0 hub
Panel Type
A-MVA3
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 60 Hz, DVI: 60 Hz, HDMI: 60 Hz, VGA: 60 Hz)
Pixel Pitch
0.49 mm
Brightness
400 cd/m²
Contrast Ratio
4000:1
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Screen Coating
7H Hard Coating, anti-smudge coating, matte
98.3 cm x 8.25 cm x 57.15 cm
19.5 kg
Plug and Play, DDC-2B, VESA DPMS, UL 60950, CB, CCC, RoHS, WEEE, cULus, REACH, SVHC, CU, DisplayPort 1.2, IP65 front
Display Type
Energy Class
Class B
111 kWh
76 W
Diagonal Size
43"
Viewable Size
42.5"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA3
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.49 mm
Brightness
400 cd/m²
Brightness w/touchscreen
336 cd/m²
Contrast Ratio
4000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
30 - 73 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Bezel Type
Raised
HDCP, High Frame Rate Control (Hi-FRC), edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, OPS slot
19.5 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Projected capacitive
VGA (HD-15) , HDMI (HDCP) , DisplayPort , USB upstream (Type B) , Audio line-in , DVI-D , Management (RJ-11)
Mechanical
VESA Mounting Interface
400 x 400 mm
Security lock slot (cable lock sold separately), metal housing, 84% light transmittance, 3 mm glass
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
Security Slot Type
Kensington security slot
AC 100/240 V (50 Hz)
65 Watt
Power Consumption Stand by
2 Watt
Included Software
Driver
Shipping Width
113 cm
Shipping Depth
19 cm
Shipping Height
71 cm
Shipping Weight
25 kg
Brand: iiyama
Price Range Ex VAT: 1000 - 1500
