With 1920x1080 Full HD resolution and Projective Capacitive 30 point touch technology, the ProLite T3234MSC-B3X delivers seamless and accurate touch response. Featuring an AMVA PID grade LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen features a vast array of inputs including DVI as well as USB for the Touch sensor itself. The ProLite T3234MSC-B3X is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard. -
AMVA
AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Multi-touch
The multi-touch functionality is available only with supported OS. -
Speakers
Built-in stereo speakers deliver rich sound.
- iiyama ProLite T3234MSC-B3X 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AMVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Voltage
- AC 120/230 V (50/60 Hz)
- 65 Watt
- Power Consumption Stand by
- 2 Watt
- 78.15 cm x 6.95 cm x 47.65 cm
- 16.2 kg
- Product Type
- 65 Watt
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- PC Interface
- DVI, VGA (HD-15)
- 78.15 cm
- 6.95 cm
- 47.65 cm
- 16.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- 7H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 405 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.364 x 0.364mm
- Response Time
- 6.5 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Colour Temperature Control
- Multitouch
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x speaker - 8 Watt
- Connector Type
- VGA input , DVI-D input , Serial output , USB , Serial input , Audio line-in , Audio line-out , Remote control
- Cables Included
- VGA cable , DVI cable , Audio cable , USB cable
- DDC-2B, VESA DPMS, TUV Bauart, IPX1
- Power Device
- Power supply
- Input Voltage
- 2 Watt
- On / Off Switch
- No
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
