Product
iiyama T3234MCS-B3X 32" 1920x1080 DVI VGA Touch LED LFD
Quicklinx: B1N9WS00 Mfr#: T3234MSC-B3X
  • 1080p (Full HD)
With 1920x1080 Full HD resolution and Projective Capacitive 30 point touch technology, the ProLite T3234MSC-B3X delivers seamless and accurate touch response. Featuring an AMVA PID grade LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen features a vast array of inputs including DVI as well as USB for the Touch sensor itself. The ProLite T3234MSC-B3X is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
  • AMVA
    AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Multi-touch
    The multi-touch functionality is available only with supported OS.
  • Speakers
    Built-in stereo speakers deliver rich sound.
iiyama ProLite T3234MSC-B3X 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
PC Interface
DVI, VGA (HD-15)
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
65 Watt
78.15 cm x 6.95 cm x 47.65 cm
16.2 kg
65 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
PC Interface
DVI, VGA (HD-15)
78.15 cm
6.95 cm
47.65 cm
16.2 kg
Enclosure Colour
Display
LCD Display Technology
AMVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
405 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.364 x 0.364mm
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Colour Temperature Control
Multitouch
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - built-in - 8 Watt
Connector Type
VGA input , DVI-D input , Serial output , USB , Serial input , Audio line-in , Audio line-out , Remote control
VGA cable , DVI cable , Audio cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
2 Watt
On / Off Switch
No
B1N9 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
B1N9 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.96
B1N9 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.34
B1N9 C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
B1N9 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
B1N9 C2G USB Superbooster Extender Kit In Stock £36.55
B1N9 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
B1N9 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
