The T2452MTS lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures.
Optical touch technology
This technology uses cameras. A touch event is registered with great accuracy when light is blocked by a finger or stylus. It's a touch technology that does not rely on an overlay or substrate to register a touch, so it's impossible to physically wear out the touchscreen. -
Stereo speakers
This LED monitor is equipped with two high-quality stereo speakers. -
ACR
ACR is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite T2452MTS-B5 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 23 W
- Touch-screen, stylus
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.272 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Black
- 55.6 cm x 22.05 cm x 39.3 cm
- 6.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class A
- 33 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 300 cd/m²
- Brightness w/touchscreen
- 260 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Dual Point Optical Touch technology, blue light reduction
- Black
- 55.6 cm x 22.05 cm x 39.3 cm - with stand
- 6.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Touch-screen, stylus - touchscreen
- Movement Detection Technology
- Optical
- VGA , DVI-D , HDMI (HDCP) , Headphones , USB
Mechanical
- Tilt
- Tilt Angle
- -3/+73
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- Dimensions & Weight Details
- Without stand - width: 55.6 cm - depth: 5.6 cm - height: 34.7 cm , With stand - width: 55.6 cm - depth: 22.05 cm - height: 39.3 cm - weight: 6.7 kg
Sustainability Information
- ENERGY STAR Certified
