iiyama T2452MTS-B5 24" 1920 x 1080 2ms LED LCD Full HD Monitor
Quicklinx: CQRHWS00 Mfr#: T2452MTS-B5
The T2452MTS lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures.
  • Optical touch technology
    This technology uses cameras. A touch event is registered with great accuracy when light is blocked by a finger or stylus. It's a touch technology that does not rely on an overlay or substrate to register a touch, so it's impossible to physically wear out the touchscreen.
  • Stereo speakers
    This LED monitor is equipped with two high-quality stereo speakers.
  • ACR
    ACR is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite T2452MTS-B5 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
23 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
AC 100 - 240 V (50/60 Hz)
55.6 cm x 22.05 cm x 39.3 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
33 kWh
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
300 cd/m²
Brightness w/touchscreen
260 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Dual Point Optical Touch technology, blue light reduction
55.6 cm x 22.05 cm x 39.3 cm - with stand
6.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D , HDMI (HDCP) , Headphones , USB
Mechanical
Tilt
Tilt Angle
-3/+73
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
23 W
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 5.6 cm - height: 34.7 cm , With stand - width: 55.6 cm - depth: 22.05 cm - height: 39.3 cm - weight: 6.7 kg
Sustainability Information
ENERGY STAR Certified
