Product
iiyama T1532SR-W1 15" 1024x768 16ms VGA DVI USB Monitor
Quicklinx: BD0VWS00 Mfr#: T1532SR-W1
Diagonal Size: 15in
Max Resolution: 1024 x 768
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£304.57 ex VAT
£365.48 inc VAT
ProLite T1532SR is an incredibly powerful touch solution based on the latest 5 Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. Extensive Touch Utilities allow for 4 point calibration and 9/25 point linerization. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the Touch Screen for cleaning. In addition the bezel free design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1532SR-W1 - LCD monitor - 15"
LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
200 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
White
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, GOST-R, IP54, TUV Bauart
Display Type
LCD monitor / TFT active matrix
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
200 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60.2 kHz
Horizontal Viewing Angle
+70 / -70
Vertical Viewing Angle
+60 / -65
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
White
4.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
Serial , DVI-D , VGA , Audio line-in , USB (Type B)
Mechanical
Tilt
Tilt Angle
-5/+90
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
20 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS 9, Apple MacOS X, Microsoft Windows 2000/XP/Vista/7
iiyama T1532SR-W1 15 Bundle deal on iiyama T1532SR-W1 15" 1024x768 16ms VGA DVI USB Monitor
£404.33
BD0V C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
BD0V C2G 5m USB 2.0 A/B Cable - Black In Stock £4.54
BD0V C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.63
BD0V C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
BD0V C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.57
BD0V C2G USB Superbooster Extender Kit In Stock £37.45
BD0V C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.15
BD0V C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Diagonal Size: 15in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
