ProLite T1532SR is an incredibly powerful touch solution based on the latest 5 Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. Extensive Touch Utilities allow for 4 point calibration and 9/25 point linerization. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the Touch Screen for cleaning. In addition the bezel free design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
- iiyama ProLite T1532SR-W1 - LCD monitor - 15"
- LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 500:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 35.1 cm x 20.1 cm x 30.6 cm
- 4.8 kg
- VCCI, DDC-2B, VESA DPMS, CB, GOST-R, IP54, TUV Bauart
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 15"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 500:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 60.2 kHz
- Horizontal Viewing Angle
- +70 / -70
- Vertical Viewing Angle
- +60 / -65
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- White
- 4.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Resistive
- Serial , DVI-D , VGA , Audio line-in , USB (Type B)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS 9, Apple MacOS X, Microsoft Windows 2000/XP/Vista/7
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
