iiyama ProLiteXUB2390HS-B1 23" 1920x1080 5ms VGA DVI-D HDMI LED IPS Monitor
Quicklinx: B1DTWS00 Mfr#: XUB2390HS-B1
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£116.94 ex VAT
£140.32 inc VAT
ProLite XUB2390HS is a 23" LED monitor with latest IPS Panel technology considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. A truly ergonomic stand including pivot function makes the XUB2390HS an excellent choice for photographic design, web design, standard office use. It’s the perfect choice for multi-monitor applications.
iiyama ProLite XUB2390HS-B1 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Swivel, tilt
53.25 cm x 23 cm x 38.6 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
PSE Mark, Green Mark, J-MOSS, TUV Bauart, VCCI Class B
3-year warranty
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
WLED
HDCP, Eco-Mode, Overdrive technology, anti-glare, Advanced Contrast Ratio (ACR)
53.25 cm x 23 cm x 38.6 cm - with stand
5.4 kg
Audio
Speakers - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in
Mechanical
Swivel, tilt
Tilt Angle
-4/+20
Swivel Angle
90
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x audio cable - 1.8 m
Power Supply
Internal
24 Watt
Power Consumption Stand by
0.5 Watt
Windows 8
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 1 year , Limited warranty - LCD panel - 1 year
5 °C
35 °C
10 - 80% (non-condensing)
iiyama ProLiteXUB2390HS-B1 23 Bundle deal on iiyama ProLiteXUB2390HS-B1 23" 1920x1080 5ms VGA DVI-D HDMI LED IPS Monitor
£216.11
B1DT C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B1DT C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.68
B1DT C2G 5m Select High Speed HDMI with Ethernet In Stock £21.95
B1DT C2G 10m Select High Speed HDMI with Ethernet In Stock £42.14
Diagonal Size: 23in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
