ProLite XUB3490WQSU is a 34" LED monitor featuring advanced IPS technology. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. UWQHD (Ultra Wide QHD) resolution offers an ultra wide viewable area. The large amount of space and good pixel density offered by the size and resolution of this screen provide great potential on the desktop. Very suitable for those who want to use side-by-side applications, watch a movie shot in widescreen format or enrich their gaming experience.
IPS technology
Offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
UWQHD resolution
This resolution offers an ultra wide viewable area. -
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier. -
Blue light reduction
The monitor's brightness and color temperature are adjusted through the blue light reduction feature that is easily accessible through the monitor’s OSD menu. -
Advanced Contrast Ratio (ACR)
Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XUB3490WQSU-B1 - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 76 kWh
- Power Consumption (On mode)
- 52.3 W
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort, MHL
- Height, swivel, tilt
- Black
- 82.75 cm x 23 cm x 40.45 cm
- 8.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, CU
- Display Type
- Energy Class
- Class B
- 76 kWh
- 52.3 W
- Diagonal Size
- 34"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 24 - 75 Hz
- Horizontal Refresh Rate
- 30 - 100 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, gamma correction, input select, colour temperature
- OSD Languages
- English, German, French, Polish, Russian, Dutch, Japanese, Chinese
- Picture in picture, picture by picture, HDCP, Advanced Contrast Ratio (ACR), i-Style Color
- Black
- 82.75 cm x 23 cm x 40.45 cm - with stand
- 8.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- 2 x HDMI , MHL / HDMI , DisplayPort , Audio line-in , Headphones , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
- -4/+20
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x audio cable , 1 x USB cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 48 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- ENERGY STAR Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£528.96
