iiyama Prolite XUB3490WQSU-B1 34" 3440x1440 VGA HDMI DP DVI Monitor
Quicklinx: CC1ZWS00 Mfr#: XUB3490WQSU-B1
ProLite XUB3490WQSU is a 34" LED monitor featuring advanced IPS technology. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. UWQHD (Ultra Wide QHD) resolution offers an ultra wide viewable area. The large amount of space and good pixel density offered by the size and resolution of this screen provide great potential on the desktop. Very suitable for those who want to use side-by-side applications, watch a movie shot in widescreen format or enrich their gaming experience.
  • IPS technology
    Offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • UWQHD resolution
    This resolution offers an ultra wide viewable area.
  • Black Tuner
    The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • Blue light reduction
    The monitor's brightness and color temperature are adjusted through the blue light reduction feature that is easily accessible through the monitor’s OSD menu.
  • Advanced Contrast Ratio (ACR)
    Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XUB3490WQSU-B1 - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52.3 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, MHL
Display Position Adjustments
Height, swivel, tilt
82.75 cm x 23 cm x 40.45 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, CU
Display Type
Energy Class
Class B
76 kWh
52.3 W
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
320 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 100 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, gamma correction, input select, colour temperature
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese, Chinese
Picture in picture, picture by picture, HDCP, Advanced Contrast Ratio (ACR), i-Style Color
82.75 cm x 23 cm x 40.45 cm - with stand
8.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
2 x HDMI , MHL / HDMI , DisplayPort , Audio line-in , Headphones , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-4/+20
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable , 1 x HDMI cable , 1 x audio cable , 1 x USB cable
48 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
ENERGY STAR Certified
