iiyama ProLite XUB2792UHSU-B1 27" 3840x2160 4ms  HDMI DVI DisplayPort 4K LED Monitor
Quicklinx: DXPQWS00 Mfr#: XUB2792UHSU-B1
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, DisplayPort
£257.31 ex VAT
£308.77 inc VAT
Stylish ultra-flat front design and 4K resolution make the ProLite XUB2792UHSU a perfect addition to the desk of any graphic designer. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the 4K (3840 x 2160) resolution means the XUB2792UHSU can accommodate 4 times more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter from what angle you look at it.
  • UHD resolution
    UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • Flicker-free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • HAS + pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
iiyama ProLite XUB2792UHSU-B1 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
33.8 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz, DVI: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 72% NTSC
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
61.4 cm x 23 cm x 39.7 cm
6.4 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV GS, PSE Mark, VCCI Class B, CU, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class G
49 kWh
Diagonal Size
27"
Viewable Size
26.9"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB, 72% NTSC
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
31 - 90 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
Ultra Slim Design, HDCP, Eco-Mode, 10-bit gamma, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, PBP, i-Style Color, 72% NTSC colour gamut
6.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Edge-to-Edge
1 x HDMI cable - 1.5 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
33.8 W
32 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: DisplayPort
Brand: iiyama
