iiyama ProLite XUB2493HS-B1 24" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor - Black
Quicklinx: DQXQWS00 Mfr#: XUB2493HS-B1
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£125.82 ex VAT
£150.98 inc VAT
Stylish edge-to-edge design makes the ProLite XUB2493HS perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor Digital Signage and office applications.
  • Advanced Contrast Ratio
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite XUB2493HS-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
18.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
54.05 cm x 23 cm x 37.8 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, CB, WEEE, PSE Mark, JEITA, VCCI Class B, EAC
3-year warranty
Display Type
Energy Class
Class A+
28 kWh
18.9 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese
Ultra Slim Design, HDCP, edge-to-edge glass
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DisplayPort , Headphones
Mechanical
Tilt Angle
-3.5/+21.5
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
iiyama ProLite XUB2493HS-B1 24 Bundle deal on iiyama ProLite XUB2493HS-B1 24" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor - Black
£224.99
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
