iiyama Prolite XUB2492HS-B1 24" HDMI DP DVI IPS Black Monitor
Quicklinx: CNKDWS00 Mfr#: XUB2492HSU-B1
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Select:
Hurry, only 1 left in stock!
£134.50 ex VAT
£161.40 inc VAT
Stylish edge-to-edge design makes the ProLite XUB2492HSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor Digital Signage and office applications.
  • IPS technology
    IPS technology offers high contrast, dark blacks and great viewing angles than standard TN technology. Thescreen will look good no matter from what angle you look at it.
  • Ultra Slim Line
    Ultra Slim Line monitors feature a sleek bezel and are therefore particularly suitable for video wall or a multi-monitor set-up.
iiyama ProLite XUB2492HSU-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
17.5 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
53.95 cm x 23 cm x 37.6 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Display Type
Energy Class
Class A+
26 kWh
17.5 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Estonian, Japanese, Chinese
Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI (HDCP) , VGA , DisplayPort , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
AC 120/230 V (50 - 60 Hz)
16 Watt
ENERGY STAR Certified
iiyama Prolite XUB2492HS-B1 24 Bundle deal on iiyama Prolite XUB2492HS-B1 24" HDMI DP DVI IPS Black Monitor
£233.67
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
