Stylish edge-to-edge design makes the ProLite XUB2292HS perfect for multi-monitor setups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences.
IPS technology
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Height-adjustable stand
With a height-adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation.
- iiyama ProLite XUB2292HS-B1 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class E
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 13.7 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Black
- 48.85 cm x 21 cm x 48.2 cm
- 4.8 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- TUV GS, PSE Mark, VCCI Class B, CU, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- 24 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Dutch, Estonian, Japanese
- Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
- Black
- 48.85 cm x 21 cm x 48.2 cm - with stand
- 4.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- HDMI (HDCP) , VGA , DisplayPort , Headphone/microphone combo jack
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.7 W
- Power Consumption SDR (On mode)
- 13.7 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 48.85 cm - depth: 21 cm - height: 48.2 cm - weight: 4.8 kg , Without stand - width: 48.85 cm - depth: 21 cm - height: 35.2 cm
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
