iiyama ProLite XU2493HS-B1 23.8" 1920x1080 4ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: DQXPWS00 Mfr#: XU2493HS-B1
Stylish edge-to-edge design makes the ProLite XU2493HS perfect for multi-monitor setups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design.
iiyama ProLite XU2493HS-B1 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
54.05 cm x 19.7 cm x 39.6 cm
3.7 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A+
28 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Japanese
Ultra Slim Design, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, Blue Light Filter technology
3.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
ENERGY STAR Certified
