iiyama ProLite XB3070WQS 30" 2560x1600 5ms VGA DVI HDMI DisplayPort IPS LED Monitor
Quicklinx: B1JLWS00 Mfr#: XB3070WQS-B1
The high color gamut iiyama XB3070WQS is the perfect choice for graphic and web-design. It features WQS (2560 x 1600) resolution offering huge workspace allowing users to display and manipulate multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent color reproduction, wide viewing angles and a fast response time. Optimal viewing comfort is guaranteed by the height adjustable stand.
  • AH-IPS
    The AH-IPS panel technology guarantees consistent color reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colors to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable.
  • High color gamut
    Color gamut tells you how large the color range of a monitor is. High color gamut panels can display a wider range of truly deep and vivid colors.
  • Height adjustable stand
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite XB3070WQS - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
104 kWh
Power Consumption (On mode)
71.3 W
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
QHD 2560 x 1600
Pixel Pitch
0.251 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
104% NTSC, 109% Adobe RGB, 146% sRGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
Voltage
69.25 cm x 23 cm x 47.7 cm
7.4 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
Display Type
Energy Class
Class C
104 kWh
Diagonal Size
30"
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
QHD 2560 x 1600
Pixel Pitch
0.251 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, blue reduction
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
69.25 cm x 23 cm x 47.7 cm - with stand
7.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , DVI-D , HDMI , Audio line-in , Headphones , DisplayPort
Mechanical
Tilt Angle
17
Swivel Angle
90
Height Adjustment
107 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x Mini DisplayPort-DisplayPort cable
Power Supply
Internal
Input Voltage
71.3 W
Power Consumption (Typical)
73 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
B1JL C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
