The high color gamut iiyama XB3070WQS is the perfect choice for graphic and web-design. It features WQS (2560 x 1600) resolution offering huge workspace allowing users to display and manipulate multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent color reproduction, wide viewing angles and a fast response time. Optimal viewing comfort is guaranteed by the height adjustable stand.
AH-IPS
The AH-IPS panel technology guarantees consistent color reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colors to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable. -
High color gamut
Color gamut tells you how large the color range of a monitor is. High color gamut panels can display a wider range of truly deep and vivid colors. -
Height adjustable stand
A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
- iiyama ProLite XB3070WQS - LED monitor - 30"
- LED-backlit LCD monitor - 30"
- Energy Class
- Class C
- Energy Consumption per Year
- 104 kWh
- Power Consumption (On mode)
- 71.3 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- QHD 2560 x 1600
- Pixel Pitch
- 0.251 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 104% NTSC, 109% Adobe RGB, 146% sRGB
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 69.25 cm x 23 cm x 47.7 cm
- 7.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
- Display Type
- Energy Class
- Class C
- 104 kWh
- Diagonal Size
- 30"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- QHD 2560 x 1600
- Pixel Pitch
- 0.251 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, blue reduction
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- Black
- 69.25 cm x 23 cm x 47.7 cm - with stand
- 7.4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- VGA , DVI-D , HDMI , Audio line-in , Headphones , DisplayPort
Mechanical
- Tilt Angle
- 17
- Swivel Angle
- 90
- Height Adjustment
- 107 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x Mini DisplayPort-DisplayPort cable
- Power Supply
- Internal
- Input Voltage
- 71.3 W
- Power Consumption (Typical)
- 73 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
