ProLite XB2783HSU - a 27" LED backlit LCD Screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24 bit ‘True Color’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite XB2783HSU will provide excellent performance for Photographic, Design and Web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
AMVA+
AMVA+ Panel technology offers 24 bit 'True Color' performance and amazing viewing angles. -
HAS + PIVOT
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
Flicker free
Controlling the monitor's brightness through electric current has allowed to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it. -
Overdrive On / Off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XB2783HSU-B1DP - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- USB 2.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.25 cm x 23 cm x 40.05 cm
- 6 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, TrueColor, Advanced Contrast Ratio (ACR), Flicker Free technology
- Black
- 6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (HDCP) , DisplayPort (HDCP) , Headphones , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
- ENERGY STAR Certified
