ProLite XB2585WSU features a PLS LED panel offering accurate and consistent color reproduction with wide viewing angles and fast response time. The ProLite XB2485WSU is a 16:10 monitor with 1920 x 1200 native screen resolution. Height Adjustable and Portrait mode stand provides the greatest comfort in use. It will provide both excellent performance for photographic and web design and is an excellent choice for universities, corporate and financial markets.
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Blue light reducer
As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows our eyes to feel less tired while working long hours with a computer screen. They achieved it by adjusting the monitor's brightness and color temperature through a feature called "Blue light reduction" easily accessible through the monitor's OSD menu.
- iiyama ProLite XB2485WSU-B3 - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 109% sRGB, 77% NTSC (CIE 1931), 81% Adobe RGB
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.1 cm x 24.45 cm x 41.6 cm
- 6.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, VCCI Class B, EAC
- Display Type
- Diagonal Size
- 24.1"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 4 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 94 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction, i-Style Color
- Black
- 6.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D (HDCP) , DisplayPort (HDCP) , Audio line-in (mini-jack) , 4 x USB 2.0 downstream (Type A) , Headphones (mini-jack) , USB 2.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable holder
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Windows 8.1, Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10
Sustainability Information
- ENERGY STAR Certified
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
