iiyama ProLite XB2474HS-B2 LED Monitor 24" 1920 x 1080 Full HD
Quicklinx: FFQJWS00 Mfr#: XB2474HS-B2
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DisplayPort, HDMI
48 in stock
£160.23 ex VAT
£192.27 inc VAT
LED backlit LCD screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration assures compatibility with many platforms.
iiyama ProLite XB2474HS-B2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Power Consumption (On mode)
20.6 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours (8-bit)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 100/240 V (50/60 Hz)
54.6 cm x 21 cm x 50.3 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, CU, REACH SvHC
Display Type
Energy Class
Class F
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Portuguese, Polish, Russian, Dutch, Estonian, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, a-Si technology
54.6 cm x 21 cm x 50.3 cm - with stand
5.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , HDMI , Headphones
Mechanical
Tilt Angle
-3/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
20.6 W
20.6 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 54.6 cm - depth: 21 cm - height: 37.3 cm , With stand - width: 54.6 cm - depth: 21 cm - height: 50.3 cm - weight: 5.3 kg
ENERGY STAR Certified
Diagonal Size: 24in
Response Time: 4ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: iiyama
Stock Status: In stock
