iiyama ProLite XB2283HS-B3 22" 1920X1080 4ms HDMI VGA DP LED Monitor
Quicklinx: DK9CWS00 Mfr#: XB2283HS-B3
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
41 in stock
£109.36 ex VAT
£131.23 inc VAT
The ProLite XB2283HS is an excellent Full HD LED-backlit monitor with resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple input support ensures compatibility with the installed graphics card and embedded Notebook outputs. The XB2283HS is also equipped with two high quality stereo speakers.
The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. It is a perfect solution for education, local government, business and finance markets.
  • HAS + Pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Flicker free
    Controlling the monitor's brightness through electric current has allowed us to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it.
  • Overdrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Use the integrated high quality speakers. Plug your headset to the headphone socket and turn the volume up.
  • ACR
    Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XB2283HS-B3 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
50.5 cm x 23 cm x 37.15 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays, VCCI Class B, CU
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
21 Watt
ENERGY STAR Certified
iiyama ProLite XB2283HS-B3 22 Bundle deal on iiyama ProLite XB2283HS-B3 22" 1920X1080 4ms HDMI VGA DP LED Monitor
£209.12
Diagonal Size: 22in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
